![]() ![]() ![]() Drives: 2013 NCP130 Join Date: Nov 2015
The ELM can reset some ECM error codes to turn off the Check Engine Light. It can read many different values such as engine temperatures, RPM, speed, fuel/air ratio, timing advance and so on. It cannot override the factory programming of the ECM. You can see many parameters of what the engine is doing, but can't use the ELM327 to modify thse values. It will not affect the performance in any way. Software such a Torque will basically allow you to have extra virtual engine instruments, and read diagnostic codes if there is a problem.
Running on standard AU 14" steel wheels (14x5 rims, 175/70R14 tyres). Added reversing camera and touch screen radio, cruise control, 16" rear wiper blade, tow bar and dash cam. |
| OBD2 Scanner/App & more | Braingasim | DIY / Maintenance / Service | 11 | 03-22-2023 09:31 AM |
| License Plate question | awebb005 | Cosmetic Modifications (Exterior/Interior) | 5 | 11-11-2014 08:28 AM |
| Voltage regulator and Amperage question... | cr.chango | DIY / Maintenance / Service | 13 | 11-24-2009 12:59 PM |
| ctrl-alt-delete question & free anti-virus question | Shroomster | Off-topic / Other Cars / Everything else Discussions | 18 | 09-08-2009 03:57 AM |
| Amplifier Watt Question....noob question | hasher22 | In Car Entertainment + Electronics (audio / video / alarm) | 4 | 09-27-2007 03:59 PM |
