Old 04-10-2019, 07:45 AM   #1
kevinj93
kevinj93's Avatar
Drives: 2013 NCP130
The ELM can reset some ECM error codes to turn off the Check Engine Light. It can read many different values such as engine temperatures, RPM, speed, fuel/air ratio, timing advance and so on. It cannot override the factory programming of the ECM. You can see many parameters of what the engine is doing, but can't use the ELM327 to modify thse values. It will not affect the performance in any way. Software such a Torque will basically allow you to have extra virtual engine instruments, and read diagnostic codes if there is a problem.
Old 04-10-2019, 07:55 AM   #2
rayfloyd170
Drives: Yaris 2016 1.3 Manual
Exactly what i was wanting to hear... Thank you for the clear and direct to the point answers. So i guess i'll have to leave it plug in. :)
rayfloyd170 is offline   Reply With Quote
OBD2 Scanner/App & more Braingasim DIY / Maintenance / Service 11 03-22-2023 10:31 AM
License Plate question awebb005 Cosmetic Modifications (Exterior/Interior) 5 11-11-2014 09:28 AM
Voltage regulator and Amperage question... cr.chango DIY / Maintenance / Service 13 11-24-2009 01:59 PM
ctrl-alt-delete question & free anti-virus question Shroomster Off-topic / Other Cars / Everything else Discussions 18 09-08-2009 04:57 AM
Amplifier Watt Question....noob question hasher22 In Car Entertainment + Electronics (audio / video / alarm) 4 09-27-2007 04:59 PM
