Old 04-22-2019, 12:56 PM   #1
zoidberg444
zoidberg444's Avatar
There is a possibility you have some partially clogged oiling passages in the engine and something isn't getting enough oil at low pressure from idling. I had a problem with my engine sounding loud and the occasional rattle from my timing chain (tensioner or the VVT) and what sounded like a very noisy lifter at idle every now and again. I ran some flush through my engine before an oil change and it hasn't done it for 10,000 miles. I guess some crud might have been blocking something after 160,000 miles/12 years.
Flush. Especially in older engines is really kill or cure though. I could just have easily have wrecked my engine and had to get a new one from the scrap yard.
Toyota timing chains are very very durable. I've only heard of a handful of cases of one going bad.
Sent from my SM-G965F using Tapatalk
- Yaris 2006, 1.0, 5 door hatchback "Betty" - 240,000 miles
UK to Nordkapp in a Yaris
Old 04-23-2019, 05:09 PM   #2
SloMo
Drives: Toyota Yaris - 2000 reg
Thanks zoidberg! It's due a service too, so I might ask the mechanic about that. I've gotten to the stage where I'm closing the windows on a hot sunny day to keep a keen ear leaning towards the engine noise! It's smoother now, but rougher than it was a few months ago. Negligible difference though. When you say Toyota timing chains are so durable, do you mean it may not need changing for another 100k, or so? Would I get some kind of warning before it goes, like a rattle or a stuttering engine?
Very grateful for all the help by posters!
SloMo is offline   Reply With Quote
Old 04-23-2019, 07:29 PM   #3
IllusionX
Drives: 07 Yaris Sedan Aero
Timing chains typically outlast the lifespan of a car, with a few exceptions like Audi's 3.2L V6 which have a premature wear of the tensioner...
Check Valve Timing (On timing chain) EMT with a Yaris DIY / Maintenance / Service 9 11-17-2018 04:29 AM
possible problem with timing chain monkeydave DIY / Maintenance / Service 6 01-17-2018 04:04 PM
timing chain help S1-crysis DIY / Maintenance / Service 5 10-03-2017 02:25 PM
Timing chain kit dillinger DIY / Maintenance / Service 10 09-28-2015 11:11 AM
timing chain or faulty sensors almcheung DIY / Maintenance / Service 3 08-16-2011 10:33 AM
