#1 |
![]() Drives: 2010 Toyota Yaris - Sedan 4 Do Join Date: Oct 2018
Check Valve Timing (On timing chain)
Hoping anyone here can elaborate on the instructions within the service manual for Checking Valve Timing
My 2010 Toyota Yaris 4 door sedan has had a code on and off (Historic/Permanent) for about 14 month now regarding Retarted Cam Timing (P0012) The Service Manual Instructions are as-follows (screenshot of page attached to this post aswell) [Page ES-71][4 - Check Valve Timing (For loose and jumped teeth on timing chain)] (a) Remove the cylinder head cover. (b) Turn the crankshaft pulley, and align its groove with the timing mark "0" on the timing chain cover. (c) Check that the timing marks on the camshaft timing sprocket and camshaft timing gear are facing upward as shown in the illustration. If not, turn the crankshaft 1 revolution (360°), then align the marks as above. OK: Timing marks on camshaft timing gears are aligned as shown in the illustration. (d) Reinstall the cylinder head cover. Im confused on how you would align the markings? I cant seem to find through the hunderds of pages this service manual instructions on how to adjust the timing chain. Thanks for any and all of your help ! |
| CHECK ENGINE !!! Dealer Blames (Oil Control Valve) | netspec239 | General Yaris / Vitz Discussion | 15 | 08-11-2018 03:31 PM |
| Cylinder head cover and timing chain cover fs | ttr125fan09 | Items for Sale by private party | 3 | 07-03-2014 09:16 AM |
| Anyone have tire check valve caps (or know someone who does) ? | nookandcrannycar | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 14 | 05-07-2014 04:31 AM |
| PCV valve check ; Can it be done this | Hershey | DIY / Maintenance / Service | 7 | 03-31-2014 09:33 PM |
| NEED ENGINE CHECK LIGHT CODE LIST | Attitude | Forced Induction Forum | 12 | 04-11-2011 06:38 PM |
