Old 04-29-2019, 12:13 PM   #1
myfirstyota
3 Yaris and counting..
Drives: 07 Yaris rs 3 door 2zr swaped
I wonder if your exhaust gasket is worn. One between the manifold and mid pipe. You're at about the mileage for a new one. I drive hard and kill them 70-80,000 km. Guaranteed that will quiet your situation down.
No one suspects the Yaris.
Xd/2zr-fe Swap/Build Thread
http://www.yarisworld.com/forums/showthread.php?t=61427
Bolt-in 3.75" Suspension Lift Build Thread
http://www.yarisworld.com/forums/showthread.php?t=61577
myfirstyota is offline   Reply With Quote
Check Valve Timing (On timing chain) EMT with a Yaris DIY / Maintenance / Service 9 11-17-2018 03:29 AM
possible problem with timing chain monkeydave DIY / Maintenance / Service 6 01-17-2018 03:04 PM
Question replacing head gasket. Snyprwlf47 DIY / Maintenance / Service 3 07-13-2014 11:17 PM
noise from timing or exhaust Redbike Europe (continental) 1 11-07-2011 03:52 PM
Help With Reverse Noise???? JoshW DIY / Maintenance / Service 0 09-09-2011 12:27 PM
