Old 05-05-2019, 10:59 AM   #1
sven337
Drives: Yaris
OK, this is fixed! Hopefully this time for good.
I had an adjustable MP1584EN-based buck module ("D-Sun" chinese brand).
These super common modules you can find for a few dollars.
For example:
https://www.ebay.fr/itm/Ultra-Small-...-/322408214136
I used my poor man's lab power supply to test what were the minimal voltage and currents needed to obtain full brightness, and I found out that a constant voltage 1.5V supply would yield a steady 300mA current that would correspond to full brightness. Going to 2.5V would increase current to 450mA without any visible change in brightness, and starting at 4V the filaments would glow red.
(Sorry about the quality of my pictures, I was focused on solving the problem and only took the pics as an afterthought).
https://perso.aquilenet.fr/~sven337/...test_setup.jpg
https://perso.aquilenet.fr/~sven337/...k/halfwatt.jpg
https://perso.aquilenet.fr/~sven337/.../2halfvolt.jpg
Once this was proven working, I cleared some space on the board by removing the transistors and their base and emitter resistors.
https://perso.aquilenet.fr/~sven337/...cleanboard.jpg
Laid out a layer of tape to insulate, soldered the module and taped it in place. This fits with room to spare when reassembling everything.
https://perso.aquilenet.fr/~sven337/...lock/final.jpg
Sorry that final picture is so anti-climactic.. Everything works quite well for now. I hope it lasts, this time, but see no reason why it wouldn't.
sven337 is offline   Reply With Quote
Old 05-07-2019, 05:23 AM   #2
Kaanktm
Drives: Yaris 1.4 D-4D 2006
For example:
Hi, thank you for sharing this. It is really helpful. Hope it lasts lifelong. :)
Could you please inform about the circuit connections on the board. I’m not bad with electronics but apparently not as good as you. Also i couldn’t find about detailed module connection schematics.
So i will appreciate and be very grateful for your reply. Thanks again. This forum rocks. :)
Kaanktm is offline   Reply With Quote
Old 05-07-2019, 04:09 PM   #3
sven337
Drives: Yaris
Are you asking about how to connect the buck module I had to the board? Assuming you have the same, but all buck modules work the same way anyway, you have three leads to connect: Vin, Vout, and GND.
If you look at my very blurry (sorry..) last picture, you can see two red wires and one black wire (at the bottom)*come out of the module. The black wire is GND, and I've taken it at the GND of the capacitor that is next to the blue inductor.
Vin was the + of this capacitor (I think the capacitor/inductor/diode here are an input filter, all I really care about is that there's a constant 12V power supply available there and it was the input of the NPN transistors).
Vout is the leftmost pin of the VFD connector (all 4 left pins are connected together).
I hope this helps you
Old 05-07-2019, 04:56 PM   #4
Kaanktm
Actually i was quite able to clear up my mind after asking the question. With your answer it is now crystal clear. Thank you so much again. Hope it would last long.
GI: "YarGauge" replacement clock module (Digital Tach, etc.) CTScott Items for Sale by private party 756 03-21-2013 09:22 PM
05 Echo changing time on clock jambo101 DIY / Maintenance / Service 3 11-12-2011 05:34 AM
Dashboard mount for iPhone 4S? shima In Car Entertainment + Electronics (audio / video / alarm) 3 10-25-2011 10:22 AM
Dashboard remove ... ALL of it Toji Cosmetic Modifications (Exterior/Interior) 7 02-26-2011 07:30 AM
Setting the clock after DST change ToddR DIY / Maintenance / Service 10 03-10-2009 12:33 AM
