Old 05-08-2019, 11:58 AM   #1
jayis
Drives: 2008 Toyota Yaris
I want to update this in case anyone ever runs into a similar problem. I am still waiting to head to a junk yard to get another screw but it's not high on my list of priorities because I have my one screw and nut holding the striker on. I did it by placing the nut in the "closed" box side of a wrench and sticking it in the holes in the rear metal until its below where the striker goes. It takes a few tries but eventually you can get it. Hopefully the pics help explain what I mean. I'm sure you don't have to use the screws and nuts that came with the car, I just wanted to. I found the part number pretty easily for the screw, and they were cheap even from Toyota (<$2). I just want other things from the junkyard anyways so I am not ordering new. Also that little part of the nut that juts out I think helps it grab and stay in place so I wanted to use the real ones.
I am pretty sure this issue is never supposed to happen and those nuts are supposed to be welded on, mine just broke somehow. I even went to the dealership to ask them if there is a part number for the nut and he told me they are part of the frame and he has no idea how they came loose.
jayis is offline   Reply With Quote
Old 08-11-2023, 12:41 PM   #2
TommyWasabi
Drives: 07 AT & 08 MT Yaris HB 3dr
Yep, this is how I fixed mine: a link to my post below in case someone finds this and needs more pictures as well.
https://www.yarisworld.com/forums/sh...165#post843165
TommyWasabi is offline   Reply With Quote
Rear brake disks sliding bolt torque Keymaster DIY / Maintenance / Service 6 04-12-2016 03:53 AM
How to set up rear window wash sprayer? Be_Jammin DIY / Maintenance / Service 0 03-13-2016 05:40 PM
2012 Nissan Versa Kal-El Off-topic / Other Cars / Everything else Discussions 22 06-15-2012 04:48 PM
