Old 06-04-2019, 12:51 PM   #1
tmontague
tmontague's Avatar
Originally Posted by Crown View Post
Hey all, a lifelong Ford man with a Yaris needs some advice
A little background: I recently inherited a 2014 Yaris LE 3D with 4500 miles. It was owned by an elderly relative since new and sat in a carport the majority of it's life, infrequently going on pretty much only short trip driving (usually 2-5 miles round trip under 30mph). I've changed the oil when I got it, as it was 2-3 year old oil...
1) Would it be wise to change out the ATF on this? I do know it's the BS "lifetime" fluid, but everyone knows about that marketing gimmick.
2) I was thinking just to do a drain and fill... (as I don't think these have an actual filter) with a compatible ATF, presumably Valvoline MaxLife, which is a thin synthetic ATF meeting specs of T-IV and WS.
3) I have done drain/fills on some 1st gen tundra sealed transmissions, where you need to do all that nonsense with getting the trans to a certain temp, poking your finger in the "check hole" etc... these just have a regular drain bolt, right?
A/T fluid tends to be fine sitting and only really begins breaking down under heat and shearing - meaning you would likely be fine leaving the trans fluid as is for another couple years.
If you do want to change it than a drain and fill is fine and much simpler than a flush. You can use the trans cooler lines to do your own flush but it likely is not needed, takes more time, is messier and costs more in fluid.
I have used Valvoline Maxlife with all of my Toyota trans flushes as it is easily accessible to me locally and is cheaper than Toyota's stuff. Also Toyota's A/T doesn't appear to be a very robust fluid (unlike their oil) compared to Valvoline and others. There is a typical drain plug on the bottom of the pan that takes an 18mm crush gasket. I'd recommend replacing it when and if you drain the fluid as it is a pain is the ass to have to replace is if you find out it's leaking afterwards (ask me how I know).
And lastly - do your Yaris a favour and go drive the sh*t out of it for a half hour.
How frequently does the automatic transmission fluid need to be changed? Hamster DIY / Maintenance / Service 40 12-15-2018 09:07 PM
T-IV Auto Transmission Fluid on Sale Now Z2TT Australia 0 03-08-2013 01:55 PM
changing transmission fluid (automatic) caineroad General Yaris / Vitz Discussion 4 07-18-2012 01:35 PM
Question for Transmission Cooler 33lam Australia 3 09-26-2010 10:54 PM
