Old 06-13-2019, 08:52 PM   #1
tmontague
tmontague's Avatar
You likely blew the fusible link which essentially a main large fuse. It is located on the plastic housing that the positive terminal is connected to. Remove your red plastic positive terminal cover and you will see 2 clear windows that show fuse links. Check if they are broken.
Replacements can be purchased from the dealer and will solve the issue if they are blown. Be thankful that the fuses exists, if they didn't your ecu and other electronics in tje car would be fried
DIY - Headlights off with the Ignition Switch CTScott DIY / Maintenance / Service 46 11-03-2018 08:42 PM
Ignition Kill switch? Deathegg DIY / Maintenance / Service 6 07-05-2011 07:17 AM
