Old 06-18-2019, 02:46 AM   #1
mat1_8
Drives: Toyota Vitz 2004 1.0
Originally Posted by johnwk View Post
It's possible that changing the transmission fluid (as in draining some and refilling) would help. However, completely flushing the transmission fluid would risk making things worse.
Have you looked at the transmission fluid dipstick? (Be sure the engine is warm and the car is idling while you check it.) It would help to make sure there's enough fluid there and that it doesn't look black or dirty.
At 66k miles, I wouldn't expect it to need a change. Do you drive on a lot of hills, or in dirt, or pulling a trailer, or in any way that might put strain on the transmission?
Hi. I have looked at the dipstick today and it seems there is the correct level of fluid and its red/brown in colour. In regards to strain, I never used the car to pull something and there aren't a lot of hills where I live. Today I am going to take it to a certified Toyota mechanic and see if he notices something. Will keep you posted. Thank you
mat1_8 is offline   Reply With Quote
Toyota yaris 2002 - Hard clutch abhinav_kr DIY / Maintenance / Service 10 06-29-2016 07:08 AM
