I run an agm powersports battery in my car with a 2zr engine and it starts no problem. Have only used it as low as 0*C and it started fine after 24 hours of sitting.
In warm weather the rule of thumb is 1CCA per cubic inch of engine. In my case I needed around 110 cc's and iirc my battery is rated at 180cca's. I have no experience with capacitors bit this is at least some real world experience with small batteries. With the 1nz engine you should be fine with just over 90 CCA's
| The Intermittent Cranking No Start Yaris VVTi mystery continues. FASTTEC used. | YarisVVTi2002 | DIY / Maintenance / Service | 2 | 09-16-2019 05:43 PM |
| 2006 Yaris Cold Start problems | cerberii | DIY / Maintenance / Service | 9 | 03-09-2018 10:52 PM |
| Yaris won't start properly/reliably | lith89 | DIY / Maintenance / Service | 10 | 11-21-2016 01:54 AM |
| Noise immediately after engine start | franic | DIY / Maintenance / Service | 10 | 02-04-2013 06:41 PM |
