Old 12-28-2012, 08:56 PM   #1
franic
Drives: Yaris sedan
Noise immediately after engine start
I have an automatic Yaris sedan 2007 with 64500 miles. Every morning when I start the engine I can hear a chirp noise immediately after the engine start (just for a second). I’ve already replaced the water pump but the problem persists. I made a test removing the serpentine belt and start the engine without that belt and the noise continue. Browsing on the internet I found a video with the same exact problem http://www.youtube.com/watch?v=9a9wYUKvako . The problem is only when the engine is off for more than 8 or 10 hrs. When I start the engine less than 2 or 3 hrs after the last on period I did not hear the sound. Did anyone has experience that? Help is appreciate
franic is offline   Reply With Quote
Old 12-30-2012, 07:05 PM   #2
franic
Drives: Yaris sedan
Yesterday, I changed the timing chain tensioner (the chain and the chain guides look good for me), this morning, the same chirp. Any advice?
Old 12-31-2012, 01:50 AM   #3
CoryM
Drives: 2009 5-door, 5-speed
Really hard to tell much from the video. Is it possible it is the sound of the starter motor not disengaging correctly? Would hear it more from the rear of the engine.
Old 01-03-2013, 04:37 PM   #4
franic
Drives: Yaris sedan
I'm just trying to convince a friend of mine to swap our starters. I appreciate your advice.
Old 01-03-2013, 05:24 PM   #5
UberSilver
UberSilver's Avatar
Drives: 08Yaris2D, 88LandCruiser.
I only thing I get from that video is the guy is holding the key in the start position too long.
UberSilver is offline   Reply With Quote
Old 01-03-2013, 05:54 PM   #6
Altitude
Altitude's Avatar
Drives: '08 LB MT Bayou
All I hear in that vid is a noisy engine (that sounds like the starter isn't disengaging) but I don't hear any "chirp".
Old 01-05-2013, 06:14 PM   #7
birdman
My starter sticks occasionally but no unusual sound. I don't hold the key in the start position but a brief second or less. My car has nearly 50k on it.
Old 01-08-2013, 03:18 PM   #8
franic
Drives: Yaris sedan
Problem solved! I've changed the solenoid (magnetic switch) and sounds like a new car. Thanks
Old 02-04-2013, 06:11 PM   #9
Doohan
Drives: Yaris TS
Where is that solenoid located?
Doohan is offline   Reply With Quote
Old 02-04-2013, 06:15 PM   #10
Doohan
Drives: Yaris TS
the small cylindrical thing right on the starter motor?
Old 02-04-2013, 06:41 PM   #11
tooter
play every day
tooter's Avatar
Drives: 2012 Yaris L 2dr 5sp
Thanks for sharing your solution, franic.
Now if I hear that chirp, I'll know exactly what to do.
check engine light, engine turns but not start willygoodness DIY / Maintenance / Service 10 07-23-2012 05:10 PM
help!! engine noise zerobuilder DIY / Maintenance / Service 3 08-12-2011 10:40 AM
Whining noise from engine bay when under load. rasper General Yaris / Vitz Discussion 2 05-07-2011 06:46 PM
engine noise?? poshi General Yaris / Vitz Discussion 23 09-04-2006 10:45 PM
