#1 | |
did you discharge that A/C Pro garbage into your vehicle? i hope not because that stuff is total junk! never use any products that contain any type of stop leak. you will most likely need to replace every component in the system if you use this stuff. also, if this "12a" uses less weight to achieve pressure it would have an adverse effect on low pressure switch and expansion valve causing a lubrication issue resulting in system damage. but, a manifold gauge set is key to diagnosing issues in A/C system... |
#3 | |
yeah, differently do not put that in your car... |
#4 | |
And yes even r134a is flammable once mixed with a/c oil, not to mention the 45L of combustible fuel behind our passengers seats. R12a runs at lower high pressure and very slightly higher low pressures so the low pressure switch has no issue recognizing the system is filled. The overall system just runs at lower head pressures which arguably can mean less wear and tear on the system. It is not a patentable refrigerant unlike Dupont's so conveted r134a. Interesting how as soon as a patent wears out suddenly a "new" refrigerant comes to the market. Up here we cannot buy r134a without a refrigerant license so r12a is the only option (more economical as well) to do our own a/c work. Also is can technically be vented to atmosphere as it is not ozone depleting I do agree not to use stop leak products unless you are just trying to get rid of the car
