Old 08-08-2019, 10:43 PM   #1
tmontague
tmontague's Avatar
Synthetic wax just tends to last longer and be more durable, it just lacks that warm glow you get with carnuba wax.
I now use ceramic coating as it lasts even longer and is much more durable than any wax. The prep takes longer but it is well worth it.
I am not sure if it will help on already peeling clear coat, but it will definitely help protect the clear coat that is still intact
Old 08-09-2019, 06:33 PM   #2
RMcG
Drives: Yaris manufactured after 2007
Thanks tmontague,
Do you think that ceramic coating (or synthetic wax) will protect underlying paint even if the clear coat has peeled off? Is there a particular brand of ceramic coating (or synthetic wax) that you (or others) prefer? (Some ceramic coatings are pretty expensive.)
My time is limited, so I may use ceramic coating or some other wipe on product for the time being, (like, e.g., a highly rated Consumer Reports wax like Nu-Finish or Meguiar's, the CR rating hopefully includes synthetic waxes) and then look into spray bombs for the base coat and a catalyzed 2K clear coat as recommended by 06YarisRS below for later.
R.
RMcG is offline   Reply With Quote
Old 08-10-2019, 10:26 PM   #3
tmontague
tmontague's Avatar
Originally Posted by RMcG View Post
Thanks tmontague,
R.
It will definitely help protect what is under it but I don't know what it will look like in the end.
I have used CQuarts UK and I am a big fan of it
Old 08-11-2019, 09:15 PM   #4
RMcG
Thanks tmontague,
I have included photos in another post in this thread. For the time being, I may just want to protect the paint as much as possible over the upcoming winter and not worry about appearance for now. And then try for a more long term solution, like the one advocated by others, like DIY painting/DIY clear coating or DIY plasti-dipping. I really don't have the money, nor the inclination to spend on a professional paint or clear coat job.
Thanks again,
R.
Tags
hood, paint, plasti dip
Anyone have / had the odor of burning / heated plastic from under the hood ? Hershey General Yaris / Vitz Discussion 26 02-18-2013 11:22 AM
i've stopped thebarber Off-topic / Other Cars / Everything else Discussions 37 12-30-2011 05:52 PM
plastic and rubber on the yaris.. matanfr Wash, Wax, Detailing, Exterior Repairs 15 01-18-2011 05:03 PM
Micro Image Hood Design Contest cali yaris Micro Image 209 10-04-2009 02:49 AM
Installed hood deflector, in-channel vent visors and hood seal. IsLNdbOi Cosmetic Modifications (Exterior/Interior) 16 12-20-2008 08:36 AM
