Old 08-15-2019, 12:48 PM   #10
ern-diz
ern-diz's Avatar
Drives: 2007 Liftback
Originally Posted by Jason@SportsCar View Post
If you like the new stops you have just make a spacer so they engage early enough to prevent the strut from bottoming. With a cheap delrin cutting board and a hole saw you should be able to make a nice spacer.
Do you also suspect that's what's happening? I'm about to install B8's and based on this thread, am trying to decide if I should run the shorter stops or get new OEM size.
My Tein springs instructed to cut the OEM stops to a specific length. If the B8's are designed to replace OEM from a ride height perspective, then they should require shorter stops in a lowered application...
On Instagram
On Wheelwell
Bump stop length for drop springs. PetersRedYaris Wheels, Tires and Suspension Forum sponsored by The Tire Rack 19 02-17-2010 08:37 AM
Another rear spring option! Honda Fit springs!! kngrsll Wheels, Tires and Suspension Forum sponsored by The Tire Rack 29 10-23-2009 05:02 PM
Option and Best motoring DVDs for sale kustom play Items for Sale by private party 1 07-08-2009 08:04 PM
I found My New Sound/DVD/Nav system! pp.sweet In Car Entertainment + Electronics (audio / video / alarm) 17 07-05-2009 01:47 PM
