Old 09-22-2019, 08:12 PM   #1
06YarisRS
Drives: 06 2ZR Turbo Yaris RS
Originally Posted by stormhighway View Post
Update 2: Had the repair scheduled for this week. The bearing went from the usual low grinding noise (indicating the bearing going bad) to sudden catastrophic failure. Wheel became detached and brake hardware disintegrated, draining brake fluid and causing the near complete loss of braking function. Thankfully occurred at low speed, but at 318,000 miles, this is the end of my Yaris.
The Duralast hub went from no noise or symptoms to catastrophic failure in 2 days and about 25 miles.
Sorry to hear that. Glad it was at low speed and you didn't get hurt. I've used some duralast parts such as brake rotors, pads etc, but, yeah, something like a wheel bearing, I'd minimally use Moog, Mevotech but would always prefer OEM, Timken or SKF. There seems to be a plethora of wheel bearing manufacturers that offer products that won't last. In this case, it really seems to be a 'get what you pay for' scenario. 318000 miles is a fair bit, but is the car not worth fixing?
ABS module and light reset 07 Yaris (sedan) DevilzMafia DIY / Maintenance / Service 6 10-02-2016 11:48 AM
Consumer Reports not too pleased with Yaris Befuddled General Yaris / Vitz Discussion 132 02-28-2011 02:57 PM
