Old 10-07-2019, 06:09 AM   #1
06YarisRS
Drives: 06 2ZR Turbo Yaris RS
Thanks very much, komichal. I hope that the peg has just slipped out as that would be an easy fix. The funny thing is, is that when I turned the dial, there was no more than the typical resistance which is almost nil. I did feel a slight snap but I suppose it could have just slipped out of the retaining hole. The video I linked was good, but didn't really show or demonstrate what causes it to pop out of its hole. And, I do hope that the flapper door is not my issue. I'm also hoping that I didn't actually damage my HVAC unit when I was creating the dent in my firewall for turbo clearance.
HVAC dripping water when AC on. Drain hose is NOT clogged. kustomrtr DIY / Maintenance / Service 3 09-07-2014 09:45 PM
HVAC Fan CB900F2 DIY / Maintenance / Service 17 06-10-2014 09:39 AM
HVAC Control Light david_827 DIY / Maintenance / Service 6 08-12-2013 11:28 AM
HVAC BLOWER ISSUES yaris2010RS DIY / Maintenance / Service 18 12-29-2012 11:23 PM
Neo Wedge LED for HVAC devinlamothe Cosmetic Modifications (Exterior/Interior) 2 04-03-2009 07:28 PM
