#1 |
HVAC Control Light
So last night as i was driving home, i realized one of my HVAC controls wouldn't light up. The control i am referring to is the one that controls the fan speed. Everything else lights up but that one. I am an electrical noob, and have no idea what could be causing this (i'm thinking maybe there is a bulb behind it that burnt out?). It confuses me even more that its only one of the knobs that is having the issue
![]() anyone know how i can tackle this issue, i'll take a picture during my commute home tonight. |
There is a little tiny bulb back there. Part number is: 90010-01113
#3 |
Thanks Scott, can i just pop the panel off and access the bulb?
#4 |
Yes. The speed control one is the easiest to replace, since the bulb is fully accessible without taking the control apart. Once you pop the panel off you will see the 3/8" round spot. Rotate it about 1/4 turn to release the bulb assembly.
#5 |
fantastic, good to know its the most easy too, appreciate the help!
#6 |
![]() Drives: 2009 Toyota Yaris Join Date: May 2012
Where is a good place to purchase the replacement bulbs? Thank you!
#7 |
Drives: 07 Yaris Sedan Aero Join Date: Oct 2006
part number mentioned above is available at any toyota dealer.
| I NEED Boost... Opinions puh-lease | Focus_Sh1ft | Forced Induction Forum | 551 | 02-08-2013 05:55 PM |
| Cruise Control on 2010 Canadian Manual | Kaya B. | DIY / Maintenance / Service | 25 | 10-01-2010 03:31 PM |
| light bulb for fan speed control burned out | bankrobber | DIY / Maintenance / Service | 2 | 09-08-2010 05:37 PM |
| Cruise control vs MPG | YarisOwnersDad | Fuel Economy Forum | 15 | 05-29-2009 03:55 PM |
| test fit 06-07 Yaris 4 door fog light | winson | California | 15 | 01-13-2009 08:25 PM |
