![]() ![]() Drives: yaris 2004 Join Date: Jul 2017
So what a happens when the car is new? Does it have some preset default data? If so, why is this not the default after a battery change and if not, how come this doesn't happen with new cars?
Odd but very annoying! Thanks for your replies - I will do this today |
Knower of little
Drives: None Join Date: Jul 2019
Some cars just do that while others don't, its a manufacture specific thing. All cars have a preset learn procedure and they'll run closed (?) loop initially while they gather data and learn to run given the data from the cars sensors. Most newer European cars won't even run when you swap the battery if you don't keep the ECU powered during the swap. It's just how it is and when it comes to new cars on dealer lots, this is a well know thing in the auto industry and dealers will not deliver a car that isn't set up and ready to go, so they'll just have someone drive it around the block before handing the car off to the new owner.
Thanks for your informative reply. I warmed up my car and ran it around a bit and it seems to be 'better'.
I do find it odd that all electronic devices use flash memory or equivalent so they don't forget so I am surprised cars don't. There must be a reason so I will dig into it and try and find out why. |
#4 | |
Knower of little
For what it's worth Subaru's do the same thing, there is a little procedure you have after a battery swap. You do a few specific things with the key in the ignition to start the learn procedure but once you start the process, the car will change idle every 10 seconds over the span of 5 minutes until it learns what it wants to do, then it's fine. If you ignore this step and just drive it, it'll idle horribly and randomly for a good few days of daily driving. I would think there is something similar for other manufactures as well.
#6 | |
I wonder if there is such a procedure for Toyota? If so, my garage hasn't heard of it and recommended a full service at vast cost when I mentioned it. Similarly, when I told them the MMT box sometimes disengaged they told me, quick as a flash, that I need a clutch and servo change..
Given the number of these low idle/stalling threads after battery disconnect, and the members we have had who are Toyota techs, I'm sure that if there was a procedure we'd have heard about it by now.
| We Have the Beats! | ern-diz | Photo-Video-Media Gallery | 41 | 05-15-2018 05:58 AM |
| 2005 Engine Oil change | mik23 | DIY / Maintenance / Service | 15 | 12-23-2016 12:23 PM |
| ***The Engine Oil Bible*** | Hussain-Vtec | Performance Modifications | 20 | 09-28-2016 02:47 PM |
| 2005 Camry Battery Update | bronsin | DIY / Maintenance / Service | 2 | 08-19-2014 10:31 AM |
| Vitz 2005 Battery | mudi | General Yaris / Vitz Discussion | 0 | 09-07-2011 02:28 AM |
