Old 08-19-2014, 10:06 AM   #1
bronsin
bronsin's Avatar
2005 Camry Battery Update
When we last left my wifes 2005 Camry we had replaced what we thought was a bad battery only to have the car shut down twice on the way to work.
This looked like an alternator problem. But when my brother in law arrived at my wifes work with a new alternator ready to install the car started and drove normally. A VOM check of the battery showed 14.5 volts. I did a check that night after she drove hom frome work and again got 14.5 volts.
So the question remained. Is the alternator really bad? And why did the car shut down twice all by itself? Was the ECM repsonsible for this?
After a week of driving the car still runs and starts and with the engine at idle theres 14.5 volts at the battery terminals.
So it looks like the alternator is good. It appears that the idiot car shuts itself off just like the Ford ingition switch that supposedly killed 13 people and led to the recall of millions of cars.
The car appears to be too smart for our own good!
Old 08-19-2014, 10:26 AM   #2
nortonfb
Drives: 2007
Gm ignition switch are the ones.
Look for a cable from the battery back shorting or a connector.
If this happens only if the car has been running a while and it starts when
cool, something is expanding and braking a connection.
Had this problem on two different cars.
Check for a fault code, could also be in the ignition system which should produce an error code.
Steve
nortonfb is offline   Reply With Quote
Old 08-19-2014, 10:31 AM   #3
bronsin
bronsin's Avatar
No CEL unfortunately I cant check for codes.
CAr has been running normally for a week.
2015 Toyota Camry Kal-El Off-topic / Other Cars / Everything else Discussions 9 04-18-2014 06:47 PM
Battery keeps going dead Outdoorsman In Car Entertainment + Electronics (audio / video / alarm) 6 09-09-2013 04:43 PM
2012 Camry Kal-El Off-topic / Other Cars / Everything else Discussions 26 10-02-2011 09:20 PM
Vitz 2005 Battery mudi General Yaris / Vitz Discussion 0 09-07-2011 02:28 AM
