I hadn't thought about that, Sam. Where I live it's always cooler than the surrounding areas as we're on the ocean. I also do a lot of driving in the fall, right up until the first snowfall. Maybe I really ought to be looking at performance all-season tire. Truthfully, I'm finding the current tires quite satisfactory but I'm really not pushing them to their limits. I'd be appreciative if you could make a suggestion of a brand of performance all- season tires that you feel would be good for all around handling, but that might be slightly more capable than a typical inexpensive tire. This of course, if you do investigate them for yourself. I did have a look at the Toyo Proxes TR1 tires in the 195/45R15 size. They look nice and can be had for a very good price
2006 Yaris 5 Door RS 2ZR-FE (2011 Corolla 1.8L) Swapped, Automatic, T-28 Turbocharged (8 psi), HSD MonoPro Coilovers, DIY W/M Injection, custom 3" cold air intake, custom 2.5" exhaust, TRD rear sway bar, Penguin Garage 13mm spacers (rear), custom Civic front lip, full repaint, Android 6.0 7" touchscreen, Rockford Fosgate speakers, tweeters, NVX underseat subwoofer https://www.instagram.com/2zr_turbo_yarisrs/ Last edited by 06YarisRS; 10-29-2019 at 07:34 PM. |
#2 | |
A tire like the TR1 is likely more tire then you need or could really take advantage of at this point based on what you have said so far. It also won't let you drive your car as much throughout the year. A slightly less sticky tire will typically squeal earlier letting you know when you are close to its limits where as a more performance oriented tire squeal happens when you are virtually at the end of the limit and sometimes it is too late to catch if you are not experienced enough to catch it before it is too late.
#3 | |
What are your thoughts on these tires? Nankang NS-25 All Season UHP in 205/55R15 https://www.ebay.com/itm/4-New-Nanka...5308e659d21418 Here is some feedback on the tires: https://simpletire.com/Reviews/items...all-season-uhp
| 3rd gen 2zr swap with 6 speed | stidnam | Performance Modifications | 97 | 06-29-2021 04:59 AM |
| Hyundai Turbo Veloster 150kw | *MAD DOG* | Off-topic / Other Cars / Everything else Discussions | 6 | 01-09-2012 11:35 PM |
| ZPI Turbo for one lucky Yaris owner..... | ZPIracing | Forced Induction Forum | 27 | 04-26-2007 10:36 PM |
