Old 02-05-2020, 11:48 AM   #1
CrankyOldMan
2ZR swap. DO IT! Ask how!
CrankyOldMan's Avatar
Weird, that's where the ECU normally is for US cars. My HB has a similar grommet on the driver's side going into the main distribution panel. If it's part of the wire harness, it's not a separate item and will have a bunch of sealant inside to keep water out of the cabin. You're probably better off just sealing it yourself, unless you want to pull the entire wire harness out of the engine bay.
Old 02-06-2020, 01:32 AM   #2
rayfloyd170
Drives: Yaris 2016 1.3 Manual
thank you for the reply...
that was what i am thinking of... i will just have to seal it then rather than pull out everything.
rayfloyd170 is offline   Reply With Quote
