2ZR swap. DO IT! Ask how!
Weird, that's where the ECU normally is for US cars. My HB has a similar grommet on the driver's side going into the main distribution panel. If it's part of the wire harness, it's not a separate item and will have a bunch of sealant inside to keep water out of the cabin. You're probably better off just sealing it yourself, unless you want to pull the entire wire harness out of the engine bay.
