Old 03-06-2020, 02:57 PM   #1
remcafee
Running with low oil and CEL on is most likely the vvti solenoid not getting oil flow and trips the check engine light, you may need to check out that solenoid
***The Engine Oil Bible*** Hussain-Vtec Performance Modifications 20 09-28-2016 02:47 PM
Original tail light without rear fog light for Yaris 3dr 2009-2011 Ot_tO Cosmetic Modifications (Exterior/Interior) 9 08-07-2012 04:27 PM
how do I reset the oil change light? Suey 1958 General Yaris / Vitz Discussion 3 04-06-2011 06:47 PM
Install Oil Pressure, Voltage and Temperature Gauges with DIY Holder bieniman DIY / Maintenance / Service 4 05-19-2009 11:40 PM
oil pressure sending unit yarissz DIY / Maintenance / Service 0 11-02-2006 06:49 PM
