Old 06-29-2020, 02:12 PM   #1
sellis
Drives: 2009 hatch
I have been thinking that 4 wheel drive and lower gears would be nice. My biggest complaint with the Yaris is it is geared to high. And then adding big tire makes it worse. 2nd gen Rav is my current choice. Full engine and trans swap. looks like it will fit but not committed enough yet to fully investigate. And adaptor to the Yaris motor may also work but the extra torque from the Rav engine would be nice.
Was thinking to just modify the rear beam by welding in trimmed Rav rear hubs. Lower and a little farther back than stock should allow axel to miss springs and will allow stock springs without spacers. And a little more space at the front of rear wheel will be nice. Will loose the spare tire well. Simple beam across to hold diff mounts. Question is how high can the diff set with the gas tank. A solid drive shaft (small) may help... A custom tank with the driveshaft through the middle may work also. I want max ground clearance so don't want it hanging down.
Next issue is keeping the exhaust up. Going to be a problem routing the rear drive and exhaust down the tunnel at front. May need to lower the front beam a bit but would like to avoid that also. Would not be apposed to using some of the passenger floor for exhaust. I don't have to sit there :)
Steering rack will likely need to move some also to allow rear drive which may require modified hubs to keep tie rods level-ish.
Anyway, Not a weekend project but looks like a hell of a lot of fun. Wish I had more spare time... or any spare time :)
sellis is offline   Reply With Quote
Suzuki Sx4 AWD...your opinions detroiter Off-topic / Other Cars / Everything else Discussions 19 06-03-2011 12:14 PM
If you were going to get an AWD car ... Thirty-Nine Off-topic / Other Cars / Everything else Discussions 28 07-12-2010 05:46 PM
PINOUT info stereo ozmdd In Car Entertainment + Electronics (audio / video / alarm) 5 12-14-2009 07:52 AM
AWD belta supmet Performance Modifications 26 03-28-2009 02:37 PM
