Old 07-07-2020, 03:05 PM   #1
ern-diz
ern-diz's Avatar
Drives: 2007 Liftback
Originally Posted by hayrider View Post
I think I found away to make it work?
I was told to pull the passenger airbag weight sensor from the stock seats and see if it will fit in the 86 seats after I remove the system from the 86 seats...
I know Toyota used the same module in a variety of models, which is why CT's bypass worked in a number of different Toyota's. If the 86 seats have a weight sensor, the fix you describe just might work. Definitely worth a try. Good luck!
On Instagram
On Wheelwell
Help modifying passenger seat to go further back. Astroman DIY / Maintenance / Service 2 09-06-2014 12:49 PM
Recalls; Seat tracks/airbag light FunkyCole DIY / Maintenance / Service 7 07-20-2014 10:29 PM
SRS warning light, pass. seatbelt light, pass. airbag light PROBLEMS! tylerwatts53 DIY / Maintenance / Service 1 07-17-2014 08:53 AM
08 Yaris, Passenger airbag off with seat belt light blink xiaoya DIY / Maintenance / Service 4 01-07-2014 09:53 AM
Rostra seat heater and lumbar support sesmith In Car Entertainment + Electronics (audio / video / alarm) 1 01-03-2009 08:51 AM
