Old 01-06-2014, 10:32 AM   #1
xiaoya
Drives: 2008 Yaris
[Solved] 08 Yaris, Passenger airbag off with seat belt light blink
Hi guys,
My beloved 08 Yaris starts to give me trouble. The passenger "airbag off" light is always on and the "seat belt" light is blinking.
A little thought: I followed CTScott's instruction to install heating pads. Did I screw the wires? Right after the installation of heating pads everything worked fine. This symptom came at 1 month after the installation.
Any advices will be appreciated.
Thank you
xiaoya is offline   Reply With Quote
Old 01-06-2014, 11:16 AM   #2
Originally Posted by xiaoya View Post
Hi guys,
Thank you
Check the two connectors on the passenger occupancy classification ECU, which is the black box mounted to the bottom of the passenger seat. That guy is not happy, which is why you are getting that error pattern for the indicators.
Old 01-06-2014, 01:37 PM   #3
xiaoya
Drives: 2008 Yaris
Thanks for the prompt reply. I will give it a check at noon when it is not freezing cold outside. It is -34 C, and -50 C with windchill in Winnipeg.
I just used OBDII scanner and found no error code but the airbag warning light is solid on in the cluster panel.
Old 01-06-2014, 01:44 PM   #4
OBDII can only read engine codes. You would need a Toyota specific scanner to read the SRS codes.
Old 01-07-2014, 10:53 AM   #5
xiaoya
Drives: 2008 Yaris
Thank you CTScott! The problem is gone.
When I check the two connectors on the passenger occupancy classification ECU (underneath the Passenger seat), the bigger was a tiny bit of loose. When I push it in a little bit I hear a click sound. Then the problem solved.
Thanks for the accurate diagnosis and prompt advices!
Passenger Airbag Question RedStickHam DIY / Maintenance / Service 13 06-23-2013 05:39 PM
Seat belt reminder warning Beep Jord DIY / Maintenance / Service 28 04-09-2009 09:37 AM
