Old 07-20-2020, 06:47 PM   #1
06YarisRS
Drives: 06 2ZR Turbo Yaris RS
Originally Posted by Desircustoms View Post
Haven't looked into the det3. I'd buy the black before the classic since you can do much more for a bit more money. I've looked at my aemlogs inj% and the fic seems to be doing it's job. Adding more fuel on the TPS map really helped. Will post screenshots later on.
Tell me more about this TPS map. I don't have one in my tune. I have a fuel map, but no TPS map. Intriguing.
Old 07-21-2020, 12:54 PM   #2
Desircustoms
Drives: 06 Yaris RS MT
TPS or maf/fuel map, depending on the load input you choose in the system options. Click the little graph icon on the top right corner of the fuel map "mouse cursor is on it" , to see the maf-TPS/fuel graph...
The fic seems to be in control even in closed loop, actually too rich for my liking, was seeing 13afr around 3k rpm 120km/h on the highway, will record with techstream later on...
I'm still experiencing hiccups sometimes, mostly on hard pulls, right after shifting, getting into 2nd or 3rd gear. Have to make fuel and maf adjustments on high rpm gear shifts.
Waiting for my wideband, the fic is great after all.
Btw I had a crankshaft position sensor code at 1st with z007 firmware, flashed it to z0100 and works great, only codes I've seen since are; maf performance and sensor1 bank 1 too rich...
Desircustoms is offline   Reply With Quote
my echo turbo build log ipwnr Forced Induction Forum 26 07-14-2015 10:09 AM
Turbo build - stage 1:D abstractmethod Forced Induction Forum 21 03-13-2014 08:04 AM
Want to build costom turbo kit. Need advice from boosted guys! pimp my yaris Forced Induction Forum 639 09-28-2013 11:26 AM
Hyundai Turbo Veloster 150kw *MAD DOG* Off-topic / Other Cars / Everything else Discussions 6 01-09-2012 11:35 PM
