#1 | |
![]() ![]() Drives: 06 Yaris RS MT Join Date: Jun 2018
#2 | |
#3 | |
The fic seems to be in control even in closed loop, actually too rich for my liking, was seeing 13afr around 3k rpm 120km/h on the highway, will record with techstream later on... I'm still experiencing hiccups sometimes, mostly on hard pulls, right after shifting, getting into 2nd or 3rd gear. Have to make fuel and maf adjustments on high rpm gear shifts. Waiting for my wideband, the fic is great after all. Btw I had a crankshaft position sensor code at 1st with z007 firmware, flashed it to z0100 and works great, only codes I've seen since are; maf performance and sensor1 bank 1 too rich... |
| Zage Turbo Kit Install - Toyota Yaris | Focus_Sh1ft | Forced Induction Forum | 160 | 02-06-2022 08:14 PM |
| my echo turbo build log | ipwnr | Forced Induction Forum | 26 | 07-14-2015 10:09 AM |
| Turbo build - stage 1:D | abstractmethod | Forced Induction Forum | 21 | 03-13-2014 08:04 AM |
| Want to build costom turbo kit. Need advice from boosted guys! | pimp my yaris | Forced Induction Forum | 639 | 09-28-2013 11:26 AM |
| Hyundai Turbo Veloster 150kw | *MAD DOG* | Off-topic / Other Cars / Everything else Discussions | 6 | 01-09-2012 11:35 PM |
