Old 08-12-2020, 11:27 AM   #1
tmontague
tmontague's Avatar
That is strange, I agree with Adam that is appears to he corrosion and not wear from lack of lubrication. That is strange however.
I'd leave it as is and drive it until/if it creates problems. The 1nz is very venerable and chances are it doesn't care about the pitting.
Just run a good quality oil changed regularily from here on out
Old 08-12-2020, 11:56 AM   #2
06YarisRS
Drives: 06 2ZR Turbo Yaris RS
The valve train might live a long life in that condition and who knows how long it's been like that. I read some info on spalling and galling of camshafts. EDIT: having trouble with a link. Will post when I sort it out.
VVT-i Oil Control Valve 06YarisRS DIY / Maintenance / Service 13 12-21-2017 10:00 PM
valve clearance specs tmontague DIY / Maintenance / Service 8 03-21-2015 08:02 AM
Valve clearance britishbikes DIY / Maintenance / Service 0 07-18-2010 09:46 AM
