Old 03-19-2015, 11:56 AM   #1
valve clearance specs
Does anyone have the specs for exhaust and intake valve clearance for an '02 Echo? Thanks
Old 03-20-2015, 08:06 AM   #2
I have them on my other computer...
Old 03-20-2015, 11:37 AM   #3
thanks Blue, if you can post them when you get a chance. I have the '08 service manual which I am assuming is the same, but I wanted confirmation before I go with that assumption. I am going to use the torque specs from the 08 manual as they should all be the same
Old 03-20-2015, 11:56 AM   #4
woops
Drives: Jeep Cherokee XJ 1996
What engine does your car have?
woops is offline   Reply With Quote
Old 03-20-2015, 01:09 PM   #5
1NZ-FE both cars have the same engine but it isn't drive by wire like the '08
Old 03-20-2015, 02:16 PM   #6
woops
got it
INTAKE: 0.15 to 0.25mm
EXHAUST: 0.25 to 0.35mm
COLD
Old 03-20-2015, 02:19 PM   #7
appreciate it
Old 03-20-2015, 02:45 PM   #8
invader166
Pumpman
Drives: 2019 Kia Soul EV Base
sweet! thx for the info!
Old 03-21-2015, 08:02 AM   #9
Here's the PDF for checking the clearances on my '05. Should be exact same.
Edit: Opps, spelled Clearance wrong haha
File Type: pdf Cylinder Head Valve Vlearance Adjusment.pdf (546.6 KB, 69 views)
Valve Noise barryware DIY / Maintenance / Service 25 02-13-2013 02:39 PM
Increased ground clearance between 2008 and 2010 Sedan unclenefeesa Wheels, Tires and Suspension Forum sponsored by The Tire Rack 6 01-17-2013 05:49 AM
Valve lifter Problem !!! Patocine DIY / Maintenance / Service 6 05-08-2012 11:09 AM
Valve clearance britishbikes DIY / Maintenance / Service 0 07-18-2010 09:46 AM
