@vasoline @tmontague
Thank you guys for your comments. I watched https://www.youtube.com/watch?v=sBJXmBJHlZc , it seems quite clear. Not sure if I will go for it though, as I can see on the video there is some extra red sealant/gunk added oll over the lid edges; is it a must-do or is there some sort of reusable factory gasket there? |
#2 | |
![]() Drives: Yaris 1.3 '08 Join Date: Sep 2014
There is no red sealant on mine (2SZ-FE) engine. It is indeed a rubber gasket. No mention of a replacement in the manual. If my repair goes well I'll re-use that gasket. The new sims are ordered. Hopefully the arrive next week. Attached is the shim replacement table for the intake cam of the 2SZ-FE engine. |
Update
Hi!
Here is my update as of 19/8/2020: - The new shims have arrived. (calculated beforehand) - I installed camshaft with new shims (added some oil to the new parts) - Measured valve clearance, with all the new parts = Ok in specification. - Returned camshaft to correct timing mark. - Returned crankshaft to cut-out mark. (needs to at 90 degrees past cut-out mark if you want to rotate the cam(s) without the chain installed. This is for non-interference with the pistons) - Installed the chain, aligned the timing marks on the camshafts with the crankshaft. - Camshaft timing mark correct position is: center, when crankshaft posistion @ cut out. I have rotated the crankshaft a few times, and the timing marks keeps aliging nicely with the camshaft's cut-out marks. What do you think? Anything forgotten? Ready to go? Tormorrow I will try to finish the job (installing valva cover, air filter) Also Is it O.k. if I post these snippets from the service manual? If not allowed, I'll remove them ps: will re-install spark plugs, this was to remove the compression and make rotating the crankshaft easy. |
| VVT-i Oil Control Valve | 06YarisRS | DIY / Maintenance / Service | 13 | 12-21-2017 10:00 PM |
| valve clearance specs | tmontague | DIY / Maintenance / Service | 8 | 03-21-2015 08:02 AM |
| Valve clearance | britishbikes | DIY / Maintenance / Service | 0 | 07-18-2010 09:46 AM |
