#1 | |
Awesome information! I wonder if it's the same for the automatic. I haven't checked it yet, but one of the reasons my new red RS failed inspection was due to the passenger side axle. I will likely have a seal on standby. A question for you, Ernie..have you changed your gear box oil? It's one of the things on my maintenance list.
#2 | |
Prior to the axle seal issues, I hadn't considered changing it. You'll find threads and posts across the forum where people have differing opinions about whether or not it's necessary. The job is easy enough, though. One bolt to drain, one bolt to fill. The most challenging part, which wasn't all that challenging at all, was Frankenstein'ing two funnels into one so it was long enough to reach the fill hole from the top of the engine. I bought the longest regular funnel Pep Boys had, along with one of those funnels that has a bendable tube and close valve on it. I pulled the tube off the second funnel and attached to the longer funnel. That gave me the length I needed to fill from above. We didn't want to mess around with a pump as that can get messy (as if things on my garage floor haven't been messy enough!). |
#3 | |
#4 | |
Having said that, I've made several drives with the car having the Valvoline oil in it (not even the synthetic stuff, just the regular $6 a quart variety) and it feels great. I've read nothing but positive remarks about Amsoil in other threads across the forum so I was thinking about trying that but after driving the car for a bit with the basic Valvoline oil in it, I'm starting to reconsider if it's even worth the time and money to flush again. I might just run the Valvoline for a while longer and see how it goes. |
#5 | |
#6 | |
Yaris Hybrid Limited 2015
https://www.blauparts.com/ravenol-ma...-3-75w-1l.html Acording to reviews on amazon it is as good as the original Toyota oil. https://www.amazon.com/Ravenol-J1C10...p?ie=UTF8&th=1
| 06 axle removal issues | TypeReaL | DIY / Maintenance / Service | 3 | 12-24-2019 09:23 AM |
| TRD Delrin Rear Axle Bushing Collars | tmontague | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 4 | 12-15-2019 07:50 PM |
| Axle Seal? | naossoan | DIY / Maintenance / Service | 18 | 07-18-2013 06:28 PM |
| Axle seal question | tforkner | DIY / Maintenance / Service | 1 | 01-28-2013 02:02 AM |
| blown axle seal ! | alfmoonspace | DIY / Maintenance / Service | 22 | 09-19-2010 08:58 PM |
