Old 01-28-2013, 12:32 AM   #1
tforkner
Drives: 08 liftback 5 speed
Axle seal question
The driver's side axle seal is leaking on my '08 hatchback. It also has 82+ thousand miles on it, so the warranty's over. I got an estimate of about $900 at the stealership to fix it. Therefore I'm gonna break out the jacks and wrenches.
I have read the manual and it says to separate the tie rod end and the lower ball joint (among other stuff, of course) in order to remove the axle shaft out. I'm kind of leery about separating the ball joint since all I have is a pickle fork. I do have a press-type tie rod separator.
Here is my question: Could I put compressors on the strut and then just unbolt the two lower strut bolts instead of undoing the ball joint?
That's how I did it on a Ford Festiva and my old Datsun Nissan Sentra Diesel (that car really had all four of those words strung across the trunk lid).
tforkner is offline   Reply With Quote
Old 01-28-2013, 02:02 AM   #2
mr_miles
Drives: 2013 Yaris
you can try just the lower strut bolts - but it shouldn't be difficult to get the ball joint out at all. just crack that bolt free and use the pickle fork and a hammer on the top of the ball joint, and it should pop right out of the hub assembly. In both of my Yar's, I did not have to use hardly any force, they came right out.
blown axle seal ! alfmoonspace DIY / Maintenance / Service 22 09-19-2010 08:58 PM
Axle seals leaking caused by lowering ride height? NH3R717 DIY / Maintenance / Service 2 07-22-2010 03:29 PM
Driver Side Axle Seal Seepage ezhacker1 DIY / Maintenance / Service 4 05-18-2010 09:54 PM
Axle Back Question _S7V7N_ Performance Modifications 17 01-20-2009 12:23 AM
Amplifier Watt Question....noob question hasher22 In Car Entertainment + Electronics (audio / video / alarm) 4 09-27-2007 03:59 PM
