Old 08-28-2020, 10:24 PM   #1
06YarisRS
Drives: 06 2ZR Turbo Yaris RS
Originally Posted by johannes2k View Post
Hi,
I have a Yaris T sport from 2001 with the 1.5 liter engine with the manual 5 speed gearbox.
I changed the trans fluid today, the toyota dealer (and the manual) stated that it would take 1.9 liters, i did add 1.9 liters but it didnt flow over the lip. Should I add more or let it be?
Thanks
/ Sweden
I'm interested in the answer to this too. I will be doing mine soon. From the brief reading I've done, I think you just keep pouring until it starts to dribble out of the upper plug. What gear oil did you use?
Old 08-29-2020, 03:20 AM   #2
johannes2k
Drives: Yaris
Yeah, I hope we get some answers! I saw another guy that asked the same thing, hes transmission didnt overflow when adding 1.9 liters.
I used the Castrol Syntrans Multivehicle 75W-90, it's API GL-4. Do not use a GL-5, even if the manual say so. ( https://www.yotatech.com/forums/f116...gl-5-a-201741/ )
johannes2k is offline   Reply With Quote
2012 Yaris hatchback, 5MT: when to change transmission oil? matti General Yaris / Vitz Discussion 14 11-18-2016 12:23 AM
Manual Transmission fluid change bankrobber DIY / Maintenance / Service 1 01-17-2010 10:32 AM
Maintenance - Change Auto Trans Fluid Linkseal DIY / Maintenance / Service 1 08-15-2006 10:57 PM
