Old 10-26-2016, 12:03 PM   #1
matti
Drives: 2017 Yaris L (5sp manual)
2012 Yaris hatchback, 5MT: when to change transmission oil?
Hello. I've got about 48k on my Yaris and it occurred to me that, as far as I can tell, the "recommended maintenance" schedule of the car doesn't say when I should change the manual transmission oil (I believe the schedule lists recommended maintenance items out to 120k miles). Any suggestions on when I should change the oil?
Thanks.
matti is offline   Reply With Quote
Old 10-26-2016, 01:56 PM   #2
bronsin
bronsin's Avatar
Depends on how you drive it. Trailer towing...below zero operation...drag racing...dusty roads etc.
Me I would follow the owners manual...
Old 10-26-2016, 02:13 PM   #3
matti
Thanks. I do, more-or-less, regular driving without too much start-stop. In winter, I do drive often when the temp is below O degrees F, however.
In regard to the owners manual, I cannot find any text giving recommended intervals for changing the transmission oil. So, I don't even know where to start.
Old 10-26-2016, 02:22 PM   #4
Go to your Toyota Service Department and ask them to print out the service schedule for your car.
Old 10-26-2016, 03:54 PM   #5
bronsin
bronsin's Avatar
Would this be DIY or would a shop do it?
Old 10-26-2016, 04:58 PM   #6
matti
I would have a shop do it. I got this response from my local Toyota dealer today:
"Toyota doesn't have a recommended mileage for transmission fluid. They recommend it gets inspected every 30K. Toyota now uses a lifetime fluid and may never need to be changed until the clutch needs replacing or maintenance. in general, many vehicles recommend a 90-100K."
Thanks again for your help everyone.
Old 10-26-2016, 05:34 PM   #7
It's surprising how many 'lifetime' fluids we are seeing touted nowadays.
Old 10-26-2016, 07:14 PM   #8
bronsin
bronsin's Avatar
If you go the no change route definitely check the level every 30000 miles and inspect the trans for leaks every oil change.
Old 10-28-2016, 12:44 AM   #9
SirDigby
Drives: 2007 yaris 3 door
change it every 50,000 miles. it only costs $20 for fluid. ($40 if you go fancy) why risk it pushing it to 100k when it's so cheap?
don't be cheap. just maintain that bitch...
Old 11-15-2016, 08:12 PM   #10
bentjazz
Drives: 2009 Yaris--3dr MT
There are two service centers where I bought my Yaris. One says to change transmission fluid no sooner than 90,000 miles. The other service center says you never have to change it. My Yaris has around 63,000 miles, and the transmission fluid is still cherry red. Plus, I have a lifetime warranty on my engine and transmission. So, I'm leaning towards never changing it, so long as the color maintains itself and there are no leaks.....
Old 11-15-2016, 09:48 PM   #11
There isn't much in a manual transmission that can create contamination. If you drive it normally and don't abuse the synchronizers the fluid could technically last as long as the clutch.
Old 11-17-2016, 12:45 AM   #12
SirDigby
Originally Posted by bentjazz View Post
... I have a lifetime warranty on my engine and transmission. So, I'm leaning towards never changing it, so long as the color maintains itself and there are no leaks.....
what kind of a moron would offer a "lifetime warranty?" sounds fishy to me.
Old 11-17-2016, 04:35 PM   #13
bentjazz
SirDigby,
Kerry Toyota, where I bought my Yaris in Dec. of 2010. One of the largest Toyota dealerships in this area. Lifetime warranty on both the engine and transmission....
Old 11-18-2016, 12:23 AM   #14
CoryM
Drives: 2009 5-door, 5-speed
I believe Toyota's official answer is the M/T fluid is not required to be serviced. Gear oil does last a long time before losing it's performance: Especially in modern gearboxes/diffs. Typically water intrusion is what ruins the fluid rather than wear.
All that being said, the fluid is cheap enough that if you change it 2 or 3 times over the life of the car it's no big expense.
Question replacing head gasket. Snyprwlf47 DIY / Maintenance / Service 3 07-13-2014 11:17 PM
Oil Change and Transmission Fluid ras3448 Third Gen Yaris General Discussion 2 09-15-2011 01:05 AM
