![]() Drives: 2009 Toyota Yaris Hatchback Join Date: Aug 2020
May I ask how did you arrange the wood blocks and the crowbar to do the bending?
Thank you, I have recently purchased this vehicle from a dealer, it came with clean engine bay. I would not clean the bay myself. By the way, this Yaris appears to have the same problem as your new RS: the areas of the body where the axle arms attach are pretty rusty, although they are not perforated yet.
#2 | |
![]() As for the rust at the subframe, my advice would be to get some oil or some other thin oil-based substance in there soon. Rust Check "red" in cans would be perfect. I'd literally unload half a can in each side. It may drip out, so putting an old blanket or something under there might be a good idea. The oblong rubber plugs just outboard of those supports should access the inner cavity. When I am done welding, I plan to drill a hole at the lowest part and install a 1/2" plastic plug. That way I can access the area easily when I do my twice annual rustproofing. Addition: If you do take out those rubber oblong plugs, you might note that the area is filled with sand and debris. I took the equivalent of about a cup of sand and crap out of each side. This is the 'design flaw in this generation of car (hatch, not sure about the sedans). That stuff in there holds water like a sponge.
2006 Yaris 5 Door RS 2ZR-FE (2011 Corolla 1.8L) Swapped, Automatic, T-28 Turbocharged (8 psi), HSD MonoPro Coilovers, DIY W/M Injection, custom 3" cold air intake, custom 2.5" exhaust, TRD rear sway bar, Penguin Garage 13mm spacers (rear), custom Civic front lip, full repaint, Android 6.0 7" touchscreen, Rockford Fosgate speakers, tweeters, NVX underseat subwoofer https://www.instagram.com/2zr_turbo_yarisrs/ Last edited by 06YarisRS; 08-31-2020 at 12:31 PM. |
#3 | |
![]() I am going to remove the oblong rubber plug and spray this product into the body cavity on each side. How does the debris get into the cavity? Would drilling a hole in the lowest part of the cavity automatically make the vehicle fail the provincial inspection?
#4 | |
Good to hear that your A/C noise is gone. I hate rattles, creaks, clunks and any other sounds that are not supposed to be there. Haha. Oh, and your car is in great shape back there, unlike many from the Maritimes. We seem to used an astronomical amount of road salt here. I think the DOT operates under the assumption that if they don't use all their salt in a year, they won't get budgeted as much the following year. I've seen them dumping salt on dry roads with no weather forecasted. End-of-rant.
Back in Edmonton they would mostly use rocks instead of salt, not a much better alternative with all the chipping and ensuing rust.
Thank you, you are very friendly and helpful, I will keep an eye on your engaging detailed repair blog. I first found this forum in 2012, it brings back many good memories, so glad it is still alive. |
#6 | |
I would prefer rock chips as they are on the outside and can be touched up. The salt is so insidious once it gets into the inner panels.
| Yaris T1 2007 Knocking Sound | varons666 | General Yaris / Vitz Discussion | 5 | 11-01-2016 05:38 PM |
| 06-10 Yaris Sedan cold air intake $40 | kylevh21 | Items for Sale by private party | 2 | 04-01-2012 03:14 PM |
| Help re my rattling Yaris! | lou3939 | DIY / Maintenance / Service | 2 | 03-11-2012 03:25 PM |
| 2007 Yaris Pricing Info ! | YarisBueller | New YARIS Purchase Forum | 104 | 06-24-2009 05:54 PM |
