![]() Drives: 08 Yaris Turbo Join Date: Sep 2020
HALTECH Connected
So I got the Haltech communicating with the laptop. The trick was buying a USB cable direct from Haltech. Don't ask me why that mattered, but apparently it does.
![]() The Haltech ESP interface looks something like this... ![]() Obviously there's a lot going on with this. There is as much access to every control, input or output to run this standalone that I could ever hope for. It will take a while to fully understand its capabilities. The first thing I checked was DTC codes. The Haltech does store them like a regular OEM ECU. I had nothing 'Current' for drive by wire but I did have some listed as 'Past'. So I brought up the live data for the pedal and watched the sweep. Haltech makes it very convenient how to observe the live data. There are several options. You can do Gauges (Like I did here) or bar graphs, data-plots, whatever suites your fancy. As an additional option, you can also select different units of measurement. (Fahrenheit instead of Celcius, etc.) ![]() Here is the LAMBDA MAP (The little blue circle tells you where the engine is at while its idling) ![]() Here is the IGNITION MAP ![]() Here is the FUEL LOAD MAP ![]() Here is the INTAKE CAM CONTROL MAP ![]() The Haltech also allows you to do DATA LOGGING while the laptop is disconnected. So you can go drive it, do some laps on the track or whatever, and hook it back up to observe what it recorded later which is very convenient. It can also 'back up' and observe the past data before a DTC code is set, after it is set, so you can figure out what the running conditions were prior to setting a DTC. (As many expensive aftermarket scan tools can also do with an OEM ECU) What I intend to do next is go do some test drives with my roommate in the passenger seat watching the live data while I drive. If there is an issue we can see in the data with the drive by wire, we should be able to record it as a snapshot. (This is basically the same stuff I do as a dealership technician with a factory scan tool.) Yesterday I took a 9 hour road trip in the Yaris to go visit Road Atlanta Motorsports Park in Georgia. There were a few occasions during that drive that I could feel something funky going on with the DBW, but thankfully nothing that locked up the pedal completely or forced me to pull over and do a shutdown-restart. The real question at this point is which component specifically is malfunctioning. The pedal or the throttle body? |
#2 | |
2ZR swap. DO IT! Ask how!
Could be deliberate to keep counterfeits from messing things up, could be someone didn't know what they were doing when they cooked it up in the R&D department. ![]() I'm afraid I don't have any feedback on the DBW issues, despite having read the report on the "unintended acceleration" issues that came up about a decade ago. |
| Does this look like a good turbo build? | SAV912 | Forced Induction Forum | 32 | 10-06-2013 01:24 PM |
| 06-10 Yaris Sedan cold air intake $40 | kylevh21 | Items for Sale by private party | 2 | 04-01-2012 02:14 PM |
| Yaris T-sport turbo/Vitz RS turbo help needed | zohard | Forced Induction Forum | 2 | 06-10-2010 06:48 PM |
| Twin turbo dual exaust yaris 1NZ-FE setup? | CtrlAltDefeat | Forced Induction Forum | 92 | 05-21-2009 12:14 PM |
