Old 04-15-2009, 03:53 AM   #1
CtrlAltDefeat
I ♥ Yaris
CtrlAltDefeat's Avatar
Question Twin turbo dual exaust yaris 1NZ-FE setup?
I was reading about turbo 3-cyl Daihatsu Charades and suddenly had a thought. The turbos on those things were pretty small... I wonder if you can run 2 small turbos off 2 cyl each of the 1NZ-FE? Like 2 turbo 2 cyl engines on a single crank. If setup right, I think the opposing cylinder would be on the power stroke while the 1st cylinder was on the exhaust stroke. I'm not sure if I'm explaining it properly so i snatched some pics off the web and drew it. Forgive the craptacular picture but I'm in a hurry and my 'shop' skill sux. Obviously the pipes would have to be equal length and as straight as possible but I think 2 Y shaped headers and 2 Y shaped turbo to to intake pipes would work.. with each turbo only working with 2 cyl I think they could be small enough to fit in the engine bay and still make plenty of power... Just some random thoughts of a engine noob... If this makes no sense what so ever, please let me know, and why. Seems like it might work pretty good...
Old 04-15-2009, 04:14 AM   #2
first things first... move this to forced induction!
Old 04-15-2009, 04:17 AM   #3
LOL aye aye cap'n
I like the idea... with some teeny tiny turbos it could be done...
But, is it really necessary? seeing the results Garm got with his small turbo, it's pretty darn responsive and good for about 180whp, i don't think the added complexity is really required... but for bragging rights, can't touch a twin-turbo Yaris
Old 04-15-2009, 04:43 AM   #4
CtrlAltDefeat
I ♥ Yaris
LOL aye aye cap'n
Yea, I can see the twinturbo badge I'd slap on the back now *goose bumps*
(oh and sorry for the mis-file for the topic...)
Old 04-15-2009, 05:03 AM   #5
CtrlAltDefeat
I ♥ Yaris
thinking about it, I wonder what will happen to the turbo during the compression and power stroke when both (ok ok all 4 ) valves are closed... must be ok, since I'm sure there are turbo 2-cyl engines out there... aren't there?
Old 04-15-2009, 05:15 AM   #6
Nexus1155
Bathroom + Laptop = <3
Drives: Audi
if you want to spend all of the money on fab work and use GT12's and be unique, thats cool. But if you want the engine self imploding on itself and tearing a black hole in the space time continium thats cool tool....
Old 04-15-2009, 05:21 AM   #7
CtrlAltDefeat
I ♥ Yaris
geez it's only a 1.5L... I think you'd need at least a 2.0L to damage the continuum
Old 04-15-2009, 11:04 AM   #8
Russelt3hPirate
l33t3st Asshole
Russelt3hPirate's Avatar
Drives: MY07 Yaris Liftback
the VAG 1.8T has already proven it can.
Russelt3hPirate is offline   Reply With Quote
Old 04-15-2009, 02:13 PM   #9
Mouse
Drives: 2007 MX5
It's been done on a 1.8 miata.....http://www.miataturbo.net/forum/t17065/
Mouse is offline   Reply With Quote
Old 04-15-2009, 02:21 PM   #10
marcus
toyota
marcus's Avatar
Drives: 2007 Yaris RS Blazed
its gonna open a black hole..hmmmmm.
Old 04-15-2009, 02:24 PM   #11
Mouse
Drives: 2007 MX5
I can't find pics of it now.....but a while back I found a pic online of what looked like a supra motor that had 6 turbos on it....It didn't have an exhaust manifold since each turbo was bolted on to the block itself. They were super tiny turbos.
Old 04-15-2009, 03:09 PM   #12
anexrx7
Drives: 08 MM HB
Well I've seen alot of 1.3 liters do some pretty nasty things... Mine is only ~350hp right now. Only wish it got the fuel efficiency of a yaris, or even my full size Chevy.
As far as the twin turbo goes, that's interesting, It would be neat to find out how well they would spool up with the pulse like that, not too sure about the efficiency on it.
anexrx7 is offline   Reply With Quote
Old 04-15-2009, 09:45 PM   #13
The Spectacle
The Spectacle's Avatar
Drives: 08 BSP LB
I'm this close to offering you money to show me pics of this...
The Spectacle is offline   Reply With Quote
Old 04-15-2009, 11:16 PM   #14
So, if twin charging is possible, would it be possible to have the said set up along with a supercharger? Massive complexity! hehehe.
Old 04-15-2009, 11:47 PM   #15
ka0sx
ka0sx's Avatar
Drives: bone f*ing stock
twin charging and keeping the intake separated doesnt do much, it also creates a power imbalance between the cylinders as the turbos will deteriorate at different rates. If you twin, then unify the intake side of it, no sense in keeping it separate. The turbine during the compression stroke will continues to spin but slow a bit due to inertia no harm done.
My question is, what is the point? I mean yeah it sounds cool on paper, but you are adding more weight then it is worth. The P to W ratio of a single compared to twin doesnt make sense, the weight cost of a larger single compared to a twin will be about a x1.6 difference due to the weight of the housing's on top of that you are running more weight with individual exhausts.
If you are doing it just to be unique and to say you did it, then go for it!
ka0sx is offline   Reply With Quote
Old 04-16-2009, 12:43 AM   #16
Mouse
Drives: 2007 MX5
Here's 4 turbos.....http://www.gizmag.com/go/5227/picture/20323/
I guess I saw wrong....But still same concept....1 turbo per cylinder.
Old 04-16-2009, 01:14 AM   #17
Morgan
Morgan's Avatar
Drives: 07 MM LB
off topic but, its a fold-able boat link from the previously posted link....
http://www.porta-bote.com/versus.html
Old 04-16-2009, 01:20 AM   #18
CtrlAltDefeat
I ♥ Yaris
ok.. maybe scratch the separate intakes, but hows about a traditional twin turbo? Sequential? Parallel? If it's works well, a twin turbo yaris would be the shit...
Turbo from Starlet on Yaris? Adamantite Performance Modifications 15 09-22-2006 05:42 AM
Vitz Rs turbo vs U.S. Yaris add turbo? weaponrcamry Performance Modifications 18 08-09-2006 08:45 PM
