#1 | ||
![]() Drives: 08 Yaris Turbo Join Date: Sep 2020
What you suggest with taking fuel control away from the stock ECU entirely will probably be safer but that will certainly not allow for closed loop operation. You can't deny (or dump fuel on top of) fuel control to the stock ECU and expect it to be happy enough to run in closed loop consistently. One trick people used to do (on older vehicles) is to try and force the stock ECU into open loop whenever you dip hard into the throttle to apply boost by cutting out the 02 sensor on command. However not every ECU goes into open loop based on O2 readings. It's essentially dependent upon load and which emissions criteria and/or functions may or may not be in play. Older cars (which I am more familiar with) switched to open loop at a certain RPMor at WOT because they had simpler emissions regs. Newer cars are in closed loop more often by design. Regardless of whichever conditions are in play any time you try to run richer than the stock ECU wants you to, it will compensate when in closed loop operation. What matters most is how much boost is made while the ECU is still in closed loop operation. The bigger the boost the bigger the risk. There are a few options on the market that do modify the O2 signal or somehow force a stock ECU back into open loop. (Piggyback kits for Miata's can do this) but even they work with varying degrees of effectiveness. The only ones that work well are developed specifically for a particular car. I am not aware of any such piggybacks that were developed specifically for a Yaris. Maybe it's possible, maybe not. What you are hoping to achieve without a full standalone, I'm afraid, is just not very likely mainly because the Yaris was not offered with boost to begin with. (At least not in the US) If it was, a piggyback controller in the league of a COBB Access Port could be used to adjust the tune relatively easily. Quote:
I could pull the pump out again to refresh my memory and take a picture for you. Yes my Yaris is no longer a return style fuel system it is a dead-head. |
#2 | |
I tried following the procedures in the video linked below, but every time I entered even the sightest decimal vlotage, my fuel trims went something like -20, regardless of how large or small the voltage input was. As perviously mentioned, I did manage to trick the ECU into delivering a rich AFR with ~2.6v in a section of the 02 map, but couldn't achieve a smooth and consistent richness as psia, rpms increased. https://www.youtube.com/watch?v=SCeMaLC0Dqo Maybe I will ultimately have to go with a standalone, but I'm hesitant at this point as I think it would be a nightmare figuring out how to control all the peripherals (DBW, A/C, cruise control etc, etc). I expect I'd be looking at many, many shop hours to get it working and then tuned. Fuel pump - So you're returnless? Isn't the Yaris returnless to begin with? Is it as simple as the wiring and strapping the pump to the assembly? No need for a fuel pressure regulator or anything else? I don't think I'm fuel starved even at full boost/rpm, though if I hold on the throttle through 6000 rpm, it will slowly start to lean a bit. I don't worry about this a lot currently, as I rarely stay in boost for long at high rpm and I have a decent amount of water being injected above 3 - 4 psi. I've seen an AFR of as lean as high 12s at 7 - 8 psi and 6000 rpm. Again, my intake temps were low (in the 70s F), high rpm, so less cylinder pressure and close to 180cc of distilled water being injected into the throttle body. If it is not a big job to yank your pump for a shot, that would be fantastic. However, please don't go to the trouble if it is an inconvenience. Thanks again. Great stuff!
2006 Yaris 5 Door RS 2ZR-FE (2011 Corolla 1.8L) Swapped, Automatic, T-28 Turbocharged (8 psi), HSD MonoPro Coilovers, DIY W/M Injection, custom 3" cold air intake, custom 2.5" exhaust, TRD rear sway bar, Penguin Garage 13mm spacers (rear), custom Civic front lip, full repaint, Android 6.0 7" touchscreen, Rockford Fosgate speakers, tweeters, NVX underseat subwoofer https://www.instagram.com/2zr_turbo_yarisrs/ Last edited by 06YarisRS; 10-04-2020 at 03:40 PM. |
| Does this look like a good turbo build? | SAV912 | Forced Induction Forum | 32 | 10-06-2013 01:24 PM |
| 06-10 Yaris Sedan cold air intake $40 | kylevh21 | Items for Sale by private party | 2 | 04-01-2012 02:14 PM |
| Yaris T-sport turbo/Vitz RS turbo help needed | zohard | Forced Induction Forum | 2 | 06-10-2010 06:48 PM |
| Twin turbo dual exaust yaris 1NZ-FE setup? | CtrlAltDefeat | Forced Induction Forum | 92 | 05-21-2009 12:14 PM |
