#1 | |
I tried following the procedures in the video linked below, but every time I entered even the sightest decimal vlotage, my fuel trims went something like -20, regardless of how large or small the voltage input was. As perviously mentioned, I did manage to trick the ECU into delivering a rich AFR with ~2.6v in a section of the 02 map, but couldn't achieve a smooth and consistent richness as psia, rpms increased. https://www.youtube.com/watch?v=SCeMaLC0Dqo Maybe I will ultimately have to go with a standalone, but I'm hesitant at this point as I think it would be a nightmare figuring out how to control all the peripherals (DBW, A/C, cruise control etc, etc). I expect I'd be looking at many, many shop hours to get it working and then tuned. Fuel pump - So you're returnless? Isn't the Yaris returnless to begin with? Is it as simple as the wiring and strapping the pump to the assembly? No need for a fuel pressure regulator or anything else? I don't think I'm fuel starved even at full boost/rpm, though if I hold on the throttle through 6000 rpm, it will slowly start to lean a bit. I don't worry about this a lot currently, as I rarely stay in boost for long at high rpm and I have a decent amount of water being injected above 3 - 4 psi. I've seen an AFR of as lean as high 12s at 7 - 8 psi and 6000 rpm. Again, my intake temps were low (in the 70s F), high rpm, so less cylinder pressure and close to 180cc of distilled water being injected into the throttle body. If it is not a big job to yank your pump for a shot, that would be fantastic. However, please don't go to the trouble if it is an inconvenience. Thanks again. Great stuff!
2006 Yaris 5 Door RS 2ZR-FE (2011 Corolla 1.8L) Swapped, Automatic, T-28 Turbocharged (8 psi), HSD MonoPro Coilovers, DIY W/M Injection, custom 3" cold air intake, custom 2.5" exhaust, TRD rear sway bar, Penguin Garage 13mm spacers (rear), custom Civic front lip, full repaint, Android 6.0 7" touchscreen, Rockford Fosgate speakers, tweeters, NVX underseat subwoofer https://www.instagram.com/2zr_turbo_yarisrs/ Last edited by 06YarisRS; 10-04-2020 at 03:40 PM. |
| Does this look like a good turbo build? | SAV912 | Forced Induction Forum | 32 | 10-06-2013 01:24 PM |
| 06-10 Yaris Sedan cold air intake $40 | kylevh21 | Items for Sale by private party | 2 | 04-01-2012 02:14 PM |
| Yaris T-sport turbo/Vitz RS turbo help needed | zohard | Forced Induction Forum | 2 | 06-10-2010 06:48 PM |
| Twin turbo dual exaust yaris 1NZ-FE setup? | CtrlAltDefeat | Forced Induction Forum | 92 | 05-21-2009 12:14 PM |
