Old 10-15-2020, 03:52 PM   #1
06YarisRS
Drives: 06 2ZR Turbo Yaris RS
Yeah, a couple of the little dinky plastic clips on mine broke at the top of the door of my new '07 project Yaris. My fault as I had a tarp jammed in both doors as I had the hood off. When I removed the tarp, it broke the clips. Didn't notice the gasket hanging down. The next day it rained. I had a soaked front seat. Doors open for two days to dry it out. I degreased the door frame, sprayed on a bit of adhesion promoter, then silicone caulked on the gasket. It's better than stock.
Improved shifting. junorico24 DIY / Maintenance / Service 3 05-22-2014 06:04 PM
Improved handling, Step By Step Spork Wheels, Tires and Suspension Forum sponsored by The Tire Rack 12 03-07-2012 12:49 PM
Improved Factory Exhuast Pipe for '08 Liftback TheSilkySmooth DIY / Maintenance / Service 10 11-10-2009 08:36 AM
