Old 03-03-2012, 12:06 PM   #1
Spork
Spork's Avatar
Drives: 1929 Ford
Improved handling, Step By Step
My wife's son has a 2007 Yaris. he wants to improve the handling so I'm going to buy some stuff for him and teach him how to install it.
I don't know diddly squat about these cars. We have a Miata that my wife drives as a DD and he likes that. Don't know if we can get close to match that in handling but would like to try.
He wanted to get new rims and tires but he's got quite a bit of life in the existing. I told him we may want to go sway bars first until the tires wear out but searching on here I see lowering, struts, coilovers, and a bunch of other ways to go.
I don't want to dump a bunch of money at a time on this thing. His birthday is coming up so I thought I'd get him something. I'd like to do upgrades on a step by step basis over time.
It is his only car but he doesn't drive a lot, lives close to his work.
What would be the first thing to do?
Thanks.
Spork is offline   Reply With Quote
Old 03-03-2012, 12:22 PM   #2
Altitude
Altitude's Avatar
Drives: '08 LB MT Bayou
First thing would be the sway bar. Hands down.
Old 03-03-2012, 12:43 PM   #3
why?
Only Happy When it Rains
why?'s Avatar
Drives: Yaris LB
yup rear sway bar:
19 mm,23 mm, or 22 mm adjustable.
Then springs/shocks or coilovers depending on how much you want to spend.
Colin Chapman disciple
Old 03-03-2012, 06:52 PM   #4
Astroman
Modded Moderator
Astroman's Avatar
I would go for a nice set of springs, after the sway bar if you wan't to do one at a time. I did springs and sway bar at the same time, along with a rear lower strut bar. Night and day for handling. Also a front strut bar will help, but you'll really only notice it on highway or extreme driving. I have the tanabe, lightweight and built well.
Old 03-03-2012, 07:56 PM   #5
^ This is all good advice, and you are welcome to call our shop to get guidance (818) 610-3635. We drive on the street, we race a lot (not on the street!), and we know the Yaris suspension pretty well at this point.
Old 03-04-2012, 03:33 PM   #6
NJ Drive
Drives: 2012 Yaris SE
Tires, rear sway bar, and a proper alignment are the best places to start.
NJ Drive is offline   Reply With Quote
Old 03-04-2012, 08:04 PM   #7
xnamerxx
0-60 in slow
xnamerxx's Avatar
Drives: light blue liftback
Skip the rear sway bar if you plan on any type of tracking with the stock springs. It will introduce some mid corner oversteer on faster turns if your driving at the limit. The downside will be you'll lose traction on corner exit. For a novice mid corner oversteer can be extremely dangerous and make it quite difficult to learn how to drive the car properly.
Old 03-04-2012, 09:56 PM   #8
malibuguy
Obsessed with 1.5L
Drives: '10 PW Yaris Sedan
MI springs with UR 23mm rear sway bar...then tires
-Greg...the Exhaust Freak.
-82 Malibu, 1uzfe swap
-97 Tercel coupe, 1nzfe/4.31
-96 Tercel 4dr
Old 03-05-2012, 04:51 PM   #9
33OH
Drives: '08 Yaris
I vote springs (shocks optional but recommended), then sway bar. The stock springs are horrible.
I would recommend Micro Image - very reputable vendor.
Old 03-05-2012, 05:09 PM   #10
chriskizi
Drives: 2012 Yaris 3-Door
sway bar, suspension, tires... wider / lower / stiffer / lighter
all helps for better handling
chriskizi is offline   Reply With Quote
Old 03-05-2012, 07:35 PM   #11
Yaristeve
Drives: 3-door hatch
Hmmmm... As you can see a lot of diferring opinions. I would buy him a book on handling and suspension theories and let him decide which compromise he would prefer. Who knows, he may not even care in which case, a set of cool looking wheels would be good enough...
Old 03-05-2012, 07:42 PM   #12
xnamerxx
0-60 in slow
xnamerxx's Avatar
An easy book to help you digest how to setup a car for handling would be HPBooks How to make your car handle.
Its a bit old but the principles are still the same plus its a easy read.
Old 03-07-2012, 12:49 PM   #13
Spork
Spork's Avatar
Drives: 1929 Ford
Well, I ordered a rear sway bar from Micro Image for him. His birthday is in a couple weeks so I'm going to install it for him. We'll see how it works.
I'm going to have to take the car out and trash it a bit to get a baseline before the swap. I've only driven it once and that was around my house in the dirt (I have an acre) and then down the dirt road we live on. It was basically to show him how to do e-brake turns and pitch the car sideways.
In addition to my hot rods, I'm a Corvette guy so I'm used to "throttle induced oversteer". That is not a concept that the Yaris (nor my step son) is familiar with!
Thanks for all the help. I'll update after the install.
DIY Cruise Control on 07-08 Yaris (step by step) Vince87 DIY / Maintenance / Service 431 12-28-2020 01:37 AM
Tutorial : Speaker Changing, Headlight Painting, Center Control Colour,Panel Removal hasher22 DIY / Maintenance / Service 88 03-06-2014 06:40 AM
Performed Meguires 3 Step Process today 3 Words HOLY FREAKING CRAP!!!! YarisSedan Wash, Wax, Detailing, Exterior Repairs 51 08-24-2009 10:02 PM
Accessory Bulb Types, anyone know? Ayka Cosmetic Modifications (Exterior/Interior) 135 04-29-2007 08:33 AM
