![]() Drives: 2013 Toyota yaris Join Date: Nov 2020
Idle problem...
Hi there.. I would like to ask if some body experience a high rpm at could start.. I have a 2012 toyota yaris 1nz fe engine.. at could start it run 1600rpm then it after while (3-5min) it goes down to 800rpm.. but before it's not like that it was only 1000rpm at cold start then goes down after 30 sec.. what do you think is the problem.. thanks you!
![]() ![]() Drives: Toyota Vios Join Date: Feb 2013
cold start easily hits 1600rpm-1900rpm, it is normal
#3 | |
![]() Drives: 1NZFE NCP93 (Vios) Join Date: Dec 2017
![]() ![]() Drives: 2007 Toyota Yaris Sedan Join Date: Feb 2019
Mine has always done 1500 rpm startup and cools down to 500 after a couple minutes
| DIY - 1.8L 1ZZ-FE TB Connector Chip Swap | Yaris T-Sport | DIY / Maintenance / Service | 332 | 04-03-2022 01:39 AM |
| Is this idle characteristic a problem? | Shinare | DIY / Maintenance / Service | 11 | 01-16-2012 07:02 PM |
| Help with low idle from Venezuela | Yarisvene | DIY / Maintenance / Service | 5 | 06-23-2007 08:23 AM |
