12-01-2020, 09:28 PM | #1 |
Drives: 2007 yaris 3 door Join Date: Sep 2015
NST Pulley FAILURE!!
hello. check out my sweet pulley!
all other pulleys turn freely. water pump turns freely. i can't find any explanation except the pulley itself being made from poop. you know, for $86 you'd think a company was using quality materials... |
12-01-2020, 09:37 PM | #2 |
Drives: '08G2T Prius Join Date: Oct 2012
Define spins "freely". Looks like to me you had the WP fail, locking up or at minimum not spinning as well as it should causing the belt to rub through the aluminum. how did you not hear or feel this happening. Definitely not a NST pulley issue imo looks like negligence.
12-01-2020, 11:58 PM | #3 |
water pump is fine. turns without effort. bearing is nice and tight. pump was replaced 25,000 miles ago. coolant is fine. 25,000 miles. pink. it did not make any noise ever until yesterday. today it was louder, so i was checking for an issue. there is not any drag what so ever. all other pulleys are in perfect shape...
12-02-2020, 09:42 PM | #4 |
Drives: 2015 H Production Yaris Join Date: Oct 2009
We only use OE pulleys now. Some years ago we had the NST crank pulley leave the crank.
2005-2008 SCCA Solo BS National Champion 2017-2018 SCCA H Prod National Champion |
12-03-2020, 03:06 PM | #5 | |
2ZR swap. DO IT! Ask how!
The reason you're paying so much for it has more to do with the limited runs. You can't get the same economy of scale that the OEMs do when they negotiate a contract for a million units per year and can amortize the costs of the equipment and engineering over the life of the program. You're paying for multiple tiers of material markup and job shop time on a slow CNC machine that takes time to set up for each part. The OEM parts are cast/stamped and machined/assembled in dedicated equipment that is optimized for speed and cost. No small shop can compete with that for raw price without losing money on the deal. All that said, that's always a bummer to have something fail so badly. |
12-03-2020, 06:55 PM | #6 | |
water pump was replaced 20k miles previous. coolant temp in AM never exceeds 80c; pm never exceeds 85c pulley temp after 10mi city/15 mi hwy is 69.2F measured with laser thermo. PULLEY IS GARBAGE!!! |
01-02-2021, 11:13 PM | #7 |
Drives: 2012 Sedan Join Date: Nov 2018
Goddamn . I was just recently thinking about buying the works engineering one. I might have to rethink that.
01-05-2021, 01:38 AM | #8 |
Gen 3 > Gen 2
Drives: NCP131, F-150 Join Date: Jul 2019
Mine is holding up fine(knock on wood), I love it.
2014 NCP131 5 Speed 2007 F150 4.2L 5 Speed 2013 Rav4 LE AWD Autotragic - Wife's |
01-08-2021, 03:28 PM | #9 |
Drives: 04 3dr HB and 04 5dr RS Join Date: Mar 2018
Does anyone make a harmonic balancer for the 1nz? I've looked around ATI's site and the 1ZZ is there but no 1NZ
01-12-2021, 12:41 AM | #10 | |
Obsessed with 1.5L
Drives: '10 PW Yaris Sedan Join Date: Feb 2011
Fun fact I worked there like 12 years ago As far as I know there is no aftermarket damper upgrades for the 1nz, just downgrades.
-Greg...the Exhaust Freak. -10 PW sedan 107whp/110wtq, full exhaust, suspension bits, TRD LSD -06 Highlander 3mzfe Limited AWD -82 Malibu, 1uzfe swap -97 Tercel coupe, 1nzfe/4.31 -96 Tercel coupe, Turbo 5efe, autoX -96 Tercel 4dr |
Tags |
fail, nst, pulley, water pump |
Thread Tools | |
Display Modes | |
Similar Threads | ||||
WTS: NST 10% underdrive pully, NST alternator and water pump pulley | 47_MasoN_47 | Items for Sale by private party | 3 | 05-15-2016 07:53 AM |
NST NonStopTuning Pulley Kits | NonStopTuning | NonStopTuning | 19 | 11-08-2014 10:23 PM |
Explain: NST Underdrive & MI pulley | evo165 | Performance Modifications | 14 | 01-08-2014 02:18 AM |
NST (NonStopTuning) Ebay Feedback & Rating | NonStopTuning | NonStopTuning | 0 | 07-19-2009 10:11 PM |
NEW GROUP BUY: NST WP-Lite & ALT-Lite Pulley Kit (NonStopTuning) | NonStopTuning | NonStopTuning | 266 | 09-29-2007 02:51 AM |
