Old 12-23-2020, 09:15 PM   #1
sacklunchz
Drives: 07 yaris
Originally Posted by 06YarisRS View Post
I agree with WeeYari that the upper strut mount washer does not contact the strut tower under load. The rubber strut mount compresses, allowing the upper part of the shaft and nut to poke up a bit. I can't say, though, that that coil looks normal. It looks too compressed. Any chance of a more perpendicular shot? Are the coil loops actually touching? They appear to be. It almost looks like the rear springs were installed on the struts.
I think you're right about the springs being on the wrong side. That would explain the problem! Looking at the springs from C-One (these are the actual ones I bought), I see that the ones with the tighter coils are next to the rears...So, yes, I will be swapping them tomorrow. Thanks for noticing that!
sacklunchz is offline   Reply With Quote
Old 12-23-2020, 09:17 PM   #2
06YarisRS
Drives: 06 2ZR Turbo Yaris RS
No prob. I would confirm with C-one first to be sure. It's just my observation that they seemed to swapped front to back. The rear is a lot lighter and, as such, the springs wouldn't compress as much.
Old 12-23-2020, 09:20 PM   #3
sacklunchz
Drives: 07 yaris
I emailed them and ill let you know what they say. But honestly I think it's almost certain you're correct. I've installed a dozen or so aftermarket springs and never seen the coils so tight. It's easy enough to swap one side and see.
thanks again friends!
))) Tein Super Compact coilover install tips ((( aucorium DIY / Maintenance / Service 4 10-25-2011 12:42 AM
Part #s for Fog Light install? Can anyone who works for Toyota confirm? IsLNdbOi Cosmetic Modifications (Exterior/Interior) 73 12-23-2010 05:15 PM
HELP needed for carputer project: Powered USB hub install Astroman In Car Entertainment + Electronics (audio / video / alarm) 15 11-01-2010 05:18 PM
