![]() Drives: JDM Toyota bB NCP31 Join Date: Oct 2020
Thank you for the help Ronnie! much appreciated.
I guess I am soon going to the tuning phase; I am now in the process of getting my down pipe welding done only. Also, I am turning from 210cc/min to 328cc/min for the injectors; could the emanage blue take that? I heard 50% increment is its max. |
#2 | |
![]() ![]() Drives: Yaris T sport TRD turbo Join Date: Aug 2017
2004 Yaris T-Sport 1NZ-FE with TRD Turbo |
#3 | |
Hi Lani, what are you doing on your machine? My boost level is 0.5 Bar I have theoretical calculation of the Injector duty increment put in a RPM vs Manifold Air Pressure chart & a ignition timing adjustment in a RPM vs Manifold Air Pressure calculated base on guess work of how much delay/advance should be made per boost; which I read online. These are calculated in excel & also comes with safety 20% safety factors; so I can tune them down when I do my tune. |
#4 | |
I could use the file as as I know someone with charger
