![]() Drives: 07 sedan Join Date: Jun 2020
Likely battery. When running it should be 13.5V + (or something)
Fully charged, about 12.5V, so you're below that in both cases... Clean the terminals and spray some anti-corrosion on them. It's a necessity in Canada. It's rare to have to change terminals on modern cars... like very uncommon, unless you constantly have put in shitty batteries which leak and form green cheese on the terminals that has rotted parts of the battery terminals. |
| The Intermittent Cranking No Start Yaris VVTi mystery continues. FASTTEC used. | YarisVVTi2002 | DIY / Maintenance / Service | 2 | 09-16-2019 05:43 PM |
| no start: engine immobilizer random issues | the_teach | DIY / Maintenance / Service | 4 | 04-13-2015 07:55 AM |
| New TSB - 2006-2015 Yaris Drive Belt Squeal Noise on Cold Start | CTScott | DIY / Maintenance / Service | 12 | 03-24-2015 06:19 PM |
| yaris voltage issue | yaris2010RS | DIY / Maintenance / Service | 11 | 12-29-2012 04:20 PM |
| Yaris sedan sputters after a cold start!! CT Scott pls help if you're out there!!!! | tyrone_yaris | DIY / Maintenance / Service | 32 | 12-03-2012 02:00 AM |
