Old 11-07-2012, 03:10 AM   #1
tyrone_yaris
Drives: Toyota Vitz 2007 facelift
Yaris sedan sputters after a cold start!! CT Scott pls help if you're out there!!!!
Hi,
For some time now my car sputters for several seconds after a cold startup but then it idles fine and runs fine. If I stop and start the engine again the next time, it starts fine without any sputtering afterwards.
Usually happens when the car is parked overnight or for a long period say 7-8 hours. Replaced all 3 spark plugs with Denso Iridium, did a throttle body and MAF sensor clean too. Also put in another battery to see if it was a battery problem but still the same sputtering after a cold start.
What could be the cause of this? CT Scott I wish you could give your opinion too.
Thanks
Tyrone
tyrone_yaris is offline   Reply With Quote
toyota yaris sedan, missing flap just inside fuel filler neck 41magmag41 General Yaris / Vitz Discussion 3 10-17-2010 04:43 PM
typicaljawaiian '09 Yaris Sedan (Cold Country, Big Island) typicaljawaiian808 Hawaii 0 10-15-2010 08:16 PM
