![]() ![]() ![]() Drives: 2013 NCP130 Join Date: Nov 2015
From memory, there was a dyno run listing from a member who discovered his 1NZ-FE was fitted with a 2NZ-FE inlet manifold. It showed a big difference when he replaced the manifold with the correct one. So there may be a difference. I would have to see the 2 side by side and compare.
Of course, if the 1NZ-FE manifold has larger cross section runners, this could actually detract from the midrange on the 2NZ-FE..
Running on standard AU 14" steel wheels (14x5 rims, 175/70R14 tyres). Added reversing camera and touch screen radio, cruise control, 16" rear wiper blade, tow bar and dash cam. |
#2 | |
![]() ![]() Drives: 2NZ ITB NCP10 Join Date: Dec 2020
The heads are the same between the two, year for year (same part number) and thats head, cams, valve springs, valves, etc etc. No difference there. The intake manifolds do have either 1NZ or 2NZ moulded into the plastic but they also "seem" identical year for year. The later model 1NZ motors look to have a different manifold where the throttle body points more upwards. I think these are ones where e-throttle is fitted. But they've all got super long, super skinny runners. There's not going to be a massive difference swapping between any of them, I'd imagine. |
| Electrical System Upgrade Advice | sqcomp | In Car Entertainment + Electronics (audio / video / alarm) | 6 | 03-23-2016 01:15 AM |
| Adding Power Trunk Release Ideas...Need Help | Jrilla | DIY / Maintenance / Service | 12 | 08-23-2009 02:38 PM |
| Plugs for power gains? | lostmind | Performance Modifications | 8 | 07-25-2007 08:19 PM |
| adding power without any cost | OxyG3nE | Performance Modifications | 13 | 04-24-2007 10:24 AM |
